Configure RSTP Ports
Configure RSTP to reduce the recovery time after a network breakdown.
- Select RSTP.
- Select the RSTP Ports tab.
- Use the fields in the RSTP Ports tab to configure the RSTP ports.
- Select Apply.
RSTP Ports Field Descriptions
Use the data in the following table to use the RSTP Ports tab.
Name |
Description |
Port |
Specifies a unique value, greater than zero, indicating the port number. |
Priority |
Specifies the value of the priority field. |
PathCost |
Specifies the contribution of this port to the path cost of paths towards the root that includes this port. |
ProtocolMigration |
Specifies a port to transmit RSTP BPDUs if operating in RSTP mode. Any other operation on this object has no effect, and RSTP mode returns false if read. |
AdminEdgePort |
Specifies the administrative value of the Edge Port parameter. A value of true indicates that this port is an edge-port, and a value of false indicates that this port is a nonedge-port. |
OperEdgePort |
Specifies the operational value of the Edge Port parameter. The object is initialized to the value of AdminEdgePort and is configured to false on reception of a BPDU. |
AdminPointToPoint |
Specifies the administrative point-to-point status of the LAN segment attached to this port. A value of forceTrue indicates that this port is treated as if it is connected to a point-to-point link. A value of forceFalse indicates that this port is treated as having a shared media connection. A value of auto indicates that this port is considered to have a point-to-point link if it is an aggregator and all of its members are aggregatable, or if the MAC entity is configured for full-duplex operation, either through autonegotiation or by management means. |
OperPointToPoint |
Specifies the operational point-to-point status of the LAN segment attached to this port. It indicates whether a port is considered to have a point-to-point connection or not. The value is determined by management or by autodetection as described in the AdminPointToPoint object. |
OperVersion |
Indicates if the port is in MSTP mode, RSTP mode or STP-compatible mode. MSTP mode transmits MST BDUs, RSTP mode transmits RST BPDUs and STP-compatible transmits Config/TCN BPDUs. |
